Stutter on initial motion
Our 2007 H45D is stuttering or vibrating a little on the initial start of motion in both forward and reverse. once the machine is moving it seems to go away until you turn one direction. The local repair shop tells us that it could be the drive motor on the right side, but the machine is not that old and only has less that 2000 hrs on it. How can one be sure of this because they are not 100% sure themselves.
  • Posted 22 Dec 2012 00:48
  • Modified 22 Dec 2012 00:49 by poster
  • By britt_v
  • joined 22 Dec'12 - 3 messages
  • Alberta, Canada
Had similar problem couple years ago it turned out to be ring gear, check teeth for any slight damage as the sensor does not like.when ring normally get t248 code but this truck had not fault codes on it. Try just lift on its own after start up see if you can get that fault code on
  • Posted 30 Jul 2016 08:24
  • By Liftkid
  • joined 2 Jun'16 - 32 messages
  • Lancashire, United Kingdom
  • By Liftkid
Did u ever find help in Canada or anywhere else? What happened to your machine? Was it fixed by rebuild / new or did you get rid of it?
  • Posted 25 Jul 2016 03:43
  • By stan_m
  • joined 25 Jul'16 - 1 message
Just a thought, could fuel be contamined,when your turning your putting a load on unit, what about fuel filter change
  • Posted 24 May 2015 06:46
  • By edward_m
  • joined 11 May'15 - 111 messages
I am refusing to pay for this work performed, but it still leaves me with a machine that does not function. Can anyone suggest a possble person for repairs in Canada.
HELP!!! No one seems to understand these machines!
  • Posted 19 Jan 2013 01:51
  • Modified 19 Jan 2013 01:54 by poster
  • By britt_v
  • Alberta, Canada
britt v;
I would be questioning the bill. If the service rep has not gone through Summerville's factory training he should be honest and let you know. Linde spent an ugly amount of money for the diagnostic software and the pressure taps in the drive train to help it's end users in unnecessary repair expenses.
  • Posted 22 Dec 2012 22:53
  • By MEngr
  • Missouri, United States
None of what you've asked has been done or saved.
The service rep came by and drove the machine and came up with this after driving it. I thought that a pressure test should be completed. He came back with they believe the drive motor is gone on one side. 10k repair. Seems wrong.
Doesn't seem qualified to me.
  • Posted 22 Dec 2012 16:46
  • By britt_v
  • Alberta, Canada
britt v;Did service rep. perform any diagnostic both on the VW engine, LDC, LHC & LTC for this 394. Was the protocol saved and did you receive a copy? Were any pressure readings taken on the HST? Note: LDC - Linde Drive Control
LHC - Linde Hyd. Control
LTC - Linde Traction Control
HST - Hydro Static Trans
  • Posted 22 Dec 2012 13:24
  • By MEngr
Maxlion FD50T
Maxlion R2D25
