apc200
Hi
Te17 transmission apc200 controller have err code 61.00 wire a24 sensor + wire going to ground
have fitted new sensor checked out wiring still same error any ideas
regards
  • Posted 22 Oct 2012 20:53
  • Modified 23 Oct 2012 04:46 by poster
  • By rikki_g
  • joined 6 Aug'12 - 20 messages
  • glam, United Kingdom
61.00 S/A Speed channel 1 (wire A24) related fault : speed
channel is shorted to ground.
When only 1 speed channel has a failiure, and which is not the
engine speed channel, the controller will calculate what the
missing speed should be. If several speed channels have a
failiure, of the engine speed channel has a failiure, the
controller reverts to a "limp home" mode.
Contact maintenance for troubleshooting Speed channel SPC1 is shorted to ground. Check the wiring between the controller and the speed sensor connected to speed
channel 1. Check the speed sensor connected to speed channel 1.
  • Posted 12 Jan 2023 06:39
  • By giorgos_k
  • joined 10 May'17 - 41 messages
  • Makedonia, Greece
Noblelift
Elwell-Parker ESI500-36
Crown CG33P5
Noblelift
