alarm 1 traction alarm 1 lift
HI, I am getting alarm 1 on both traction and hyd controllers. Battery voltage is fine as are fuses. I am getting my 48v pos supply to the contactor but don't seem to be getting the neg. Anybody any ideas of where i could be losing the negative or why my main contactor is not being supplied the neg. My traction controller is testing ok.
Thanks
  • Posted 20 Oct 2012 03:00
  • By diesel123
  • joined 10 Jun'09 - 20 messages
  • antrim, United Kingdom
Hi Diesel,
Is the main contactor coming in,truck will still light up the display even if this doesn't come in,obviously make sure you have 48v both sides of the contactor,or at the 2 main heavy fuses,as they're sealed you can't actually see tips,so will need to check with a meter,and have you also checked the small microswitch on the side of the emergency disconnect?
  • Posted 29 Aug 2014 04:09
  • By spannerboy
  • joined 31 Jul'13 - 12 messages
as a general rule, negative is supplied through the controller.
  • Posted 4 Aug 2014 10:14
I have same problem....
  • Posted 4 Aug 2014 08:59
  • By jollydjoger
  • joined 8 Jun'13 - 23 messages
  • Sofia, Bulgaria
Ncn 85TH
Ncn 85TH 2014
Aichi RX07B
