brakes
doin a brake job and got all hardware in correctly put all backtogether and drove for 10 mins and was fine....1hr later customer called and said the brakes were locked up and didn't go inreverse cause of the tight brakes, so went back and adjusted the star adjuster and brought them all the way in(which I did the first time also but somehow they were back out) again truck drovefine for a bit and the same problem persists so anybody got ideas??? I'm going there shortly to check the e-brake tightness
  • Posted 24 Aug 2012 22:15
  • By straightup
  • joined 24 May'12 - 2 messages
  • Michigan, United States
Have had this happen to me before and someone recommended using loctite on the adjuster and it worked great. I believe that Clark has had a few issues with the "master cylinder", there has been a few versions.
  • Posted 30 Aug 2012 08:31
  • By rogeriwt
Yes, one way to tell if it is a fluid pressure drag is to loosen a brake pipe fitting or a bleeder screw and see if you get a squirt of fluid out and if the drag goes away.
  • Posted 26 Aug 2012 23:18
  • By L1ftmech
  • Tennessee, United States
Good call mrfixit- is the brake push rod adjusted correctly?
  • Posted 26 Aug 2012 10:43
  • By bbforks
The master cylinder may be pressurizing the brake system even without pressing the brake petal.
  • Posted 26 Aug 2012 08:23
Aichi SR18A
Crown CG33P5
edition #1257 - 20 November 2025
Aichi SR18A
Crown CG33P5
Oxford Ct, United States
Columbus, United States
