WP2300
Hi All -
I am having a blow out the control fuse of a WP2300 walkie by Crown. At the same time the controller got damage I have changed two of them.
I opened a controller and I found melted the pcb trace between terminal A-2 and anode of the diode is connected at this terminal.
There are three ways after cathode one is coming to another cathode diode which I belive it is not flowing current becuase it has inverse polarization, the second one is goinf to +BV which is battery positive side thru main contactor and it is a deviation to the BRS in,. the third one is going to C-1 connector and is looped to the C-2.
Can anyone tell me where I can start in order to find out this problem?
  • Posted 11 Apr 2007 11:40
  • By luis_v
  • joined 25 Feb'07 - 127 messages
  • Mexico
I will start doing it. I will tell you what I did and what I got.
I have looked at the control handle and it is complete different to the previos one (WP2000).
  • Posted 12 Apr 2007 01:14
  • By luis_v
  • Mexico
Check the power cables going to the drive motor from the Zapi controller,for short circuit to the frame of the truck. Also check the drive motor itself,for possible problems.
  • Posted 11 Apr 2007 21:28
  • By Truck_Tech
  • United States
Terberg RT223
SMV (Konecranes) 4632CC5
Terberg RT223
