Hyster 120 xl 3
Get problem with Code 94 brusch worn
Check every thing but they perfect.
This appears every time when i thake A direction en when I drive
en this only for 1 second end is gone.
There is 1 box monted for Traction en 1 interface (pomp) and my cabels from bruches coming in that interface card.
Is some wone their they can help me with this problem.
Or with some drawings or explenatie of this interface end the code's of this type of lifttruck.
Kindly regards
john Netherlands
  • Posted 31 Mar 2007 16:40
  • By genjohn
  • joined 4 Feb'07 - 59 messages
  • NB, Netherlands
Check also brush wear sensor.Make sure p5 and p6 is not shorted.Also if you have a diffrent pump controler to try to see if code still occurs.Hope that helps
  • Posted 1 Apr 2007 22:56
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
OKE I'am sorry
I'ts not EV 100
Their is one box grey general electric (Traction)
And A small box I think A interface for lift and communicatie to dashboard.
lifttruck got 4 contactors
I see this never be for
I see only EV 100 and 200 and 2 grey box general electric POMP and DRIVE
  • Posted 1 Apr 2007 15:14
  • By genjohn
  • NB, Netherlands
wow i was trying to be helpful not hurtful
o well
i speak spanish (not well but i have to in new york these days) and i appreciate corrections
i dont yell at some1 trying to help me
so ill give you and your post a big "bronx cheer"
  • Posted 1 Apr 2007 05:40
  • By justinm
try dutch When you speak dutch Than you can sea 3 words lol
Try my langage
sorry you try
Zeg mij maar een s na in jou taal ut
vertaal het eens.
  • Posted 1 Apr 2007 05:32
  • Modified 2 Apr 2007 05:43 by administrator
  • By genjohn
  • NB, Netherlands
seeing it only shows up for a second the sensor harnsess might have a loose or dirty connection although im not sure how that hyster would be set up
im imagining it has an ev200 system like the 1 i have in my area
a few english corrections (as im sure its not your everyday language) just to help
cable not cabel
brush not bruch
"1 second end is gone." should be "1 second and is gone."
"some wone their they can help" should be "someone there that can help" there, their, and they're can be very tricky to use correctly when english is a second language
im part dutch too but i can speak maybe 3 words lol
speaking of good english translations
"have a good luck"
  • Posted 1 Apr 2007 03:09
  • By justinm
Briefs United States
GemOne
