error code c016 e025
hi all,
My stacker is stuck and i have the error codes c016 and e025 showing. Any idea what the problem would be and how to solve it ? Thanks in advance for the help
  • Posted 14 Apr 2012 06:32
  • By Patrickk
  • joined 14 Apr'12 - 1 message
  • Papeete, French Polynesia
Patrick
11 Offset error armature /
field current (DC)
Stator current (AC);
Current measurement
point
F, H, L,
F-AC, H-AC
CONTROLLER Check main current wire, replace
component
Travel no function
  • Posted 24 Feb 2015 03:54
  • By joram_s
  • joined 5 Feb'11 - 117 messages
  • madrid, Spain
Hi
I have en error on EJE116 C016 and E011.
Whats is mean ?
How to solve this problem ?
Thank s
Anis
mydotanis(at)gmail(dot)com
  • Posted 24 Feb 2015 02:13
  • By junus_a
  • joined 30 May'12 - 49 messages
  • west java, Indonesia
you never walk alone
Hola.
71
Rotura de cable del potenciometro
de descenso.
I2, FS POTENC. DESCENSO Comprobar conexion de cables; cambiar
potenciometro de descenso; cambiar
Multipiloto; cambiar interface.
Mandame un mail.
  • Posted 30 Dec 2014 03:12
  • Modified 30 Dec 2014 03:13 by poster
  • By joram_s
  • madrid, Spain
Email soyjoram@gmaildotcom
Hola Joram
Podrias decodificar el E071 y C096 para el EJC110 con AS2409K ??
gracias
Luis
  • Posted 30 Dec 2014 02:21
  • By luis_y
  • joined 24 Oct'04 - 29 messages
  • Lima, Peru
All makes, the best service.
- no logon from
interface
- no telegrams from
Can-Bus travel switch
F, H, I4, I8
F-AC, H-AC
L
INTERFACE / CAN Check CANBus connection, check
wire connection between proportional
valve - modulation; check fuse 1F8;
replace iInterface (I2, I4, I8) ; replace
lift potentiometer, Multipilot, Solopilot
or interface;
MP1510C: Voltage collapses,
controller logs on again, interface does
not, controller remains blocked and
waits for interface.
Check battery voltage (with load!);
charge or replace battery if necessary;
AS2409K: no "live" telegram received
from CAN Bus travel switch for more
than 300 ms; replace travel switch
  • Posted 3 May 2012 20:56
  • By joram_s
  • madrid, Spain
Michel Denis Michel Denis
Nagano NUL120-6
Maxlion MTF25-60-2WD
