Code 30.1 30.2 30.3
I have codes coming up
First fault code is 30.3
When side shift lever is opperated but only some times?
Then lift pump shuts down.
Some times motor runs very slow?
  • Posted 18 Nov 2011 07:17
  • By pacfork
  • joined 2 Jun'07 - 55 messages
  • British Columbia, Canada
The code is low volts to A/C controller. Is that the only code? I would check switch and wiring.
  • Posted 18 Nov 2011 12:48
  • By rogeriwt
Mitsubishi FGE35AT
Terberg YT222
REPOWERTEK Inc
REPOWERTEK Inc
