Electric
I have an Toyota FBM20 (the type-plate also says FSVE6 and FBM25-11153).
First it sometimes didn't drive and didn't lift and showed the error-codes EA, CA.
But sometimes all was ok and it worked correct.
Sometimes it did drive, but didn't lift.
Sometimes it didn't lift, but did drive.
Then I found a thread in the forum, where "franco c" told to replace C70 - C10 - C12 - C90 - C80 - C60 - C82 - D4 - D5 - ZD90 - R28 - Q90 on the DC/DC-board.
I replaced C70 - C10 - C12 - C90 - C80 - C60 - C82, because some of them leaked.
I also replaced D4 and D5, but I took IN4007instead of the originals, because there was nothing to read on the old ones.
Then I tried again. First it worked, but only for some seconds. Sometimes, if I turn off and on the key, it works again for a short time.
But now it also shows error-codes C0 or C4 sometimes.
And as before, it sometimes works and sometimes not.
Can somebody tell me, which are the correct replacement-diodes for D4, D5 and ZD90 ?
Has anybody got a repair-manual and the error-codes?
Thanks for your help, Tom.
  • Posted 4 Nov 2011 01:52
  • By fromatoa
  • joined 4 Nov'11 - 1 message
  • Oberösterreich, Austria
Michel Denis Michel Denis
Crown CG33P5
Manitou M50-4
Crown CG33P5
Manitou M50-4
