OBDII Adapter?
Is there an OBDII adapter to connect to 4-pin connector on truck? TB45 Engine
  • Posted 10 Sep 2011 00:23
  • By carl_v
  • joined 12 Oct'07 - 76 messages
Hi tool king, where you get the sst for k21 engine and part number?
  • Posted 21 Aug 2023 01:47
  • By prepaito_d
  • joined 17 Dec'17 - 177 messages
  • iztapalapa, Mexico
Whatsapp +525513637801
The cable has a obdII connector on one end and a four pin plug on the other that will plug right into the machines harness.
  • Posted 20 Oct 2011 10:00
  • By tool_king
  • joined 1 Jun'10 - 21 messages
  • New Jersey, United States
what are your "local dealers"
we are different than the states, we cannot just plug into the komatsu's and retrieve ecm fault codes....
  • Posted 19 Oct 2011 00:00
  • By Jrworks
  • joined 18 Oct'11 - 1 message
  • Alberta, Canada
Hello,
Is there another # for the Cable? This part # is not working for our local dealers.
Thanks
  • Posted 29 Sep 2011 07:40
  • By tundra
  • joined 29 Sep'11 - 5 messages
  • Alberta, Canada
ToolKing, thank you. I am near Harrisburg
  • Posted 16 Sep 2011 06:12
  • By carl_v
Yes order this cable from komatsu Intermediate Cable Part No. # 3EA-55-36680 if it is a nissan gas engine.Cable will let you use any oddII scanner for engine problems..If you have latop you can also use service tool kit / Part No. 3EB-97-50010 for engine dianostics or you will the hand set with the k21/k25 cartridge.Where in PA are you?
  • Posted 11 Sep 2011 15:02
  • Modified 12 Sep 2011 03:49 by poster
  • By tool_king
Toyota 02-8FD30
Terberg YT222
