CROWN PC4500-80 CODE 140 BROKEN CHAIN
ww
  • Posted 20 Apr 2011 07:59
  • Modified 27 Apr 2011 09:51 by poster
  • By ryan_k
  • joined 20 Apr'11 - 1 message
check the coupler that joins the POT4 to the drive unit for excessive wear.
it sounds to me like the coupler may be getting to much slack in it and causing it the show out of range.
if the coupler is ok and the problem keeps coming back you may have to swap the Access 5 out with a truck that is not having this problem and see if the problem goes with the Access 5 to the other truck. if the Access 5 turns out to be the problem keep in mind that the Access modules are usaually covered under warranty for 3 years or 3500 hrs which ever comes first.
good luck
bruce_c
  • Posted 21 Apr 2011 01:49
  • By bruce_c
  • joined 28 Jul'10 - 52 messages
  • Missouri, United States
