Travel Problem
After about five minutes of normal use the travel will have intermitting problems and the directional contacts will click in and out fast. It starts off a little and get worse the longer in use. This happens in forward and reverse. Already checked the pot, swapped the drive motor, and swapped traction card. Any ideas? Thanks.
  • Posted 26 Feb 2011 08:33
  • By Wes27
  • joined 26 Feb'11 - 3 messages
  • Mississippi, United States
We did check the voltage from the directional switches to the card and it was equal. Someone told me to test the capacitors on the transistor panel. I was on another job today, so I'll be back on this truck tomorrow.
  • Posted 1 Mar 2011 13:08
  • By Wes27
  • Posted 1 Mar 2011 13:07
  • By Wes27
Back-up. First, trace out the directional control circuits,from the distibution panel,through the mast cables to the directional switches,and back down through the mast cables to both inputs on the transistor control card. The EV100T (ZC) cards are very sensitive to low voltage inputs(below 21VDC).
  • Posted 1 Mar 2011 12:46
  • By Truck_Tech
  • United States
Taylor X550M
Nagano NUL120-6
Taylor X550M
Nagano NUL120-6
Sue Tomic Sue Tomic
