crown RR5000 series lift height
Hello is the lift height "stop" adjustable on a Crown RR5020-45 fork truck? It is new to us ( used). While raising the forks they stop going up at about nine feet. The digital read out for the height in inches says 105" and it beeps and the screen reads "RAISE CUTOUT". Need it to go higher nobody in the shop can figure it out. It looks like it has the potential to go much higher. Is there a way to adjust it?
Thanks
  • Posted 15 Feb 2011 09:13
  • By nooster
  • joined 15 Feb'11 - 2 messages
  • Missouri, United States
the next info is all your truck is.
(obiously if the serial number is correct)
Truck Specifications
Serial Number: 1A213928
Model Number: RR5020-45
Spec Record Number: Spec Line:
10 Standard
20 Model Number - RR5020-45
30 High Visibility Triple Telescopic Mast
40 Lifting Height - 210 "
50 Collapsed Height - 95.00"
60 Extended Height - 257.62"
70 with 48" Load Backrest
80 Inside/Outside Straddle - 34/45"
90 36V Volt Electrical System
100 Numbered Color Coded Wiring
110 42" Power Unit
120 Variable Position Side Stance
130 Five Point Operator Positioning
140 C Battery Compartment, Code 10
150 Min./Max. Battery Weight - 2000/2490 lbs
160 Tilt - 3 Deg.Forward/4 Deg.Back
170 Suspended Floor Board w/Non Skid Mats
180 System Hour Meters :
190 - Power-On,Traction,Lift
200 Crown Integrated Control System
210 w/Access 1*2*3 Diagnostics
220 Proportional Hydraulic Control
230 Multi-Task Control Handle
250 OPTIONAL FEATURES
260 Battery Connector - SB350 Gray
270 Forward Steering
280 Sideshifter - 4.00" each way
290 Standard Fork Spread - 27.00
300 5 X 4.1 Load Wheels -35 Compound
310 Poly Drive Tire - Standard
320 42" Std Forks
330 Enhanced Information Display
340 -Alpha/Numeric Display
350 -Capacity Data Monitor
360 -Productivity Package Included
370 Increased Travel Speed
380 Increased Lower Speed
390 Std Speed Lift Pump
400 Mast Guard - Glass
410 US English Decals
420 Capacity Information(@ 24" Load Center)
430 4500 lbs Capacity to 210"
440 4500 lbs Capacity to 210"
450 Video Tape to Ship With Truck - NTSC
460 **Manufacturing Code -
470 13150/8650/6160/39.5
  • Posted 16 Feb 2011 06:02
  • By raul_s
  • joined 17 Jun'10 - 134 messages
  • San Luis Potosi, Mexico
your trouble is too easy to resolve, the only thing is you must call a technician to know the access system. and he can resolve in 5 minutes.
you can't use it, if don't turn over the cutout.
but if you provide your e-mail i can send the steps to off that option.
regards
r7346842 at gmail dot com
at = @
dot =.
  • Posted 16 Feb 2011 02:39
  • By raul_s
The buttons are found on older Crown RR's. If this truck is an RR5000 the height cut out can be adjusted through the access modules. This will need to be completed with a service book and knowledge of the system. I would suggest calling a service company to help you out.
  • Posted 15 Feb 2011 11:33
  • By Miloslouis
  • joined 4 Dec'10 - 27 messages
The serial number is 1A213928 also says truck type E. I don't know about the button switches I will have to check tonight at work.
Thanks
  • Posted 15 Feb 2011 09:32
  • By nooster
without a serial number, any answer is just a guess.
as you stand on the unit, are there some button switches mounted under the lip right near your left hip?
  • Posted 15 Feb 2011 09:23
