Clark GCX25 engine
I have a Clark GCX25 sn GX230-524-9085kf with a bad Mitsu 4G54, I also have a new 4G64 on the shelf. Does anyone know if this would bolt in ?
  • Posted 4 Feb 2011 09:28
  • By dana_b
  • joined 4 Feb'11 - 1 message
  • Washington, United States
Hi, John. yes i knew Rodolfo in the 1990. but my father works in Allis Chalmers San Luis Potosi from 1978 to 1988 to closely with Rodolfo, after that he work in DYS,ME a dealer in SLP. i work in this stuff since 1990. my first forklifts was the Mitsubishi, i think i have his e-mail and i can provide you.
  • Posted 10 Feb 2011 07:08
  • By raul_s
  • joined 17 Jun'10 - 134 messages
  • San Luis Potosi, Mexico
pastrana j
Thanks for you reply.
Yep, Rodolfo S. called me in 1986 when I went to work for Mitsubishi in Houston, TX & explained that AC shutdown the lift truck operation in SLP & the government of Mexico lifted the import duties on lift trucks & he had 10 dealers that needed a lift truck line. We made an agreement - I was UDIMACs primary contact - we grew the business from zero Mitsubishi in Mexico to more than 600 units per year in 5 years. Visited Mexico often, always enjoyed my visits, the cervesas, no sleep at night & a stay at Vista Hermosa.
If you have an email address for Rodolfo please provide in this format xxxxxxxxxx at yyyyyy dot zzz.
  • Posted 9 Feb 2011 03:23
  • By johnr_j
"Have An Exceptional Day!"
johnr-j
I know Rodolfo Slobotsky because I worked with an allis chalmers dealer from 1977 to 1982. A.C forklifts was made as you said in San Luis Potosi. After that, UDIMAC brougth to MEXICO the Mitsubishi forklift brand. After that Mr.Slobotsky began with the intrupa spares in Mexico till intupa was acquired for smh. Now he is in a new spareparts bussines.
  • Posted 8 Feb 2011 05:12
  • By pastrana_j
  • joined 3 Aug'10 - 103 messages
  • Puebla, Mexico
raul,
I have been to San Luis Potosi. My last time (~1990) was when I worked for Mitsubishi in Houston and I worked closely with Sr. Rodolfo Slobostky when he was with UDIMAC - do you know him? I knew Rodolfo from my Allis Chalmers days. Allis Chalmers used to build lift trucks in S.L.P then Gleaner combines.
  • Posted 6 Feb 2011 08:49
  • By johnr_j
That's right John, your mitsubishi engines 4G54, 4G64, both mus be made for clark forklift, otherwise you will have many problems.
  • Posted 6 Feb 2011 07:12
  • By raul_s
You also need to understand the Mitsusbishi engine Clark used was not made in Japan. It was made in Korea under a licensing agreement. Just a couple key differences is the Clark version had dynamic (Lancaster type) balancers for the crank shaft & the front crank pulley was different as the Mitsubishi fork lifts drove the hydraulic pump off the crank.
  • Posted 6 Feb 2011 03:06
  • By johnr_j
if you new motor is a 4G64, yes, there is possible, but you need to do many many changes, unfourtunately the technical bulletins for do that i have not.
if the new motor is a 4G63, not, that can't do it
sorry.
  • Posted 6 Feb 2011 01:52
  • By raul_s
No it won't
  • Posted 5 Feb 2011 06:39
  • By johnr_j
Enforcer FD50T-MMA
Maxlion MTF25-60-2WD
