side shift
Hi guys
New to the game and need a bit of advise if poss
I have a few h25d with odd problems
L222 Comes up but only if you sit on seat ,if you start the oftruck off machine it work guess its the seat switch but this was changed recently ??
Also I have a side shift with no power it is a meyer system and another engineer has told me its the ram seals
They have a circlip on the outside so does this mean the end cap has to be pushed in to find a circlip on the inside ?????? to remove it to allow access to the piston
I am not sure it is this as the joystick has had water in it
thanks
scorpion
  • Posted 13 Oct 2010 14:27
  • By Scorpion
  • joined 13 Oct'10 - 6 messages
  • KENT, United Kingdom
the L222 refers to the joystick not being in neutral when truck started, this usually means joystick is worn and needs replacing
  • Posted 14 Oct 2010 20:23
  • By comet
  • joined 17 Nov'09 - 19 messages
  • Sounty Durham, United Kingdom
Unicarriers FD80-2
JLG G12-55A
Michel Denis Michel Denis
Unicarriers FD80-2
JLG G12-55A
