code -11
GETTING 26 V ON ONE SIDE OF START SWITCH (FROM) BRAKE SWITCH AND 37V ON OTHER SIDE. SHOWING 26 VOLTS AT TB2 WITH KEY OFF ANY SUGGESTIONS
  • Posted 16 Sep 2010 09:49
  • Modified 16 Sep 2010 09:49 by poster
  • By paul_i
  • joined 16 Sep'10 - 4 messages
  • Michigan, United States
26 volts pos and 16 v neg customer to put board under battery i am sure the motors need blow out as well
  • Posted 17 Sep 2010 05:59
  • By paul_i
What tests have you done on the Battery??? Case to frame test???
  • Posted 16 Sep 2010 21:52
  • By Prentice
Sue Tomic Sue Tomic
