EV100 settings, for a non-conventional use
This one I know there is probably some answers that are not going to be typical......I'm just looking for a place to start here.
I am building an electric car. I have saved ALL of the electronic components from a old stand up forklift, and am in the process of installing them into a Geo Metro.
I have a GE 6.7" traction motor already bolted up to the transmission, and am ready to start the re-wiring process.
Now, I saved pictures of EVERY wire that was disconected, so I do know where everything goes......
what should my settings be for my EV100? The car will typically be driven in 1st. 2nd and 3rd gear, with an estimated top speed of 30MPH. Curb weight is 1900 - 2000LBS, but gearing is a bit taller than a conventional forklift. Should I be setting my time for the (don't remember what to call it.....) "Up to top speed" very short, or longer? My thoughts were to set it very short, and let the 1A take most of the abuse.........like I said, just my thoughts...
Here is my cards info....
EV100T1TT1
serial number - PR LX-047766
  • Posted 26 Jul 2010 23:55
  • By CrazyBry79
  • joined 26 Jul'10 - 5 messages
  • Wisconsin, United States
Since the EV100 goes into 1A timer when accelerator voltage reaches 0.5V, I would adjust to the shortest time, as you were thinking.
  • Posted 31 Jul 2020 23:33
  • By KOBrien
  • joined 18 Mar'20 - 12 messages
Good luck on your build Crazy. I converted a '65 Corvair Monza using a GE EV1-D panel, and a drive motor from an old Cat M30. Currently running on 96 volts, it's a little slow - around 65mph top speed. It has the original powerglide transmission. I have the 1A time set high, so it doesn't come in until i want it to - at full pedal. That way when I reach desired cruising speed the controller doesn't try to go into 1A when my "gas" pedal is almost fully depressed. The pot box has a 1A switch at full pedal. I would guess to do the same when using a standard transmission.
  • Posted 31 Jul 2020 22:49
  • By KOBrien
Sue Tomic Sue Tomic
UN Forklift FD15-18T
Terberg RT223
Sue Tomic Sue Tomic
Terberg RT223
