LPG and the Impco Converter
Has anybody information on Impco converters. We no longer see model J or K here in the UK. They were replaced some time ogo with "Cobra." I understand because of an accident in Germany, where an operator pressed the tester/cold start on the secondary chamber for too long causing and engine explosion. There must have been more to the storey than that! Because the Filter Lock valve should stop such occurances. We have seen the button shrouded on some Converters but not on others. Also if you buy a new "Cobra" Converter the button has now been removed. I have not seen that on new production FLT's yet. What are the rules on this button and its shroud now in the US? Impco training information is very hard to come buy here in the UK. Any body know where I can get it?
  • Posted 12 May 2006 22:53
  • By DaveUK
  • joined 12 May'06 - 44 messages
  • BERKSHIRE, United Kingdom
Who bravely dares must sometimes risk a fall.
Showing items 1 - 20 of 21 results.
then the lock-off and regulator are both bad, and once repaired/replaced, you should start training the operators to turn off the gas at the tank when ever the truck is going to be sitting more than just a few minutes and for sure at the end of the day.
  • Posted 2 Jan 2010 23:38
...And what if the vaporizer frosts-up before start-up? It also floods the mixer/intake manifold with liquid fuel at air temps below 0 c.
thanks,
  • Posted 2 Jan 2010 07:59
  • By TeeCee
  • joined 2 Jan'10 - 1 message
  • Washington, United States
peace-out..
as far as the impco model J, all i do to test them these days is to remove the small pipe plug in the test port, and replace the plug with a barb fitting. i then install a vacuum/fuel pressure gauge onto this barb fitting and observe the primary pressure. Pressure should hold fairly steady at 1&1/2 to 2PSI with the engine running, and hold that pressure without climbing or dropping with the truck shut off.
if the truck is equipped with a VFF30 fuelock, remove the vacuum line to the fuelock with the engine running. the truck will stall as soon as the pipe between the fuelock and the vaporiser is exhausted of fuel. this time will vary from a second if it's simply a pipe nipple connecting the two, to thirty seconds if it's a long hose. if the engine simply sputters, or does not stop at all, the fuelock is stuck partially or completely open.
if the vaporizer housing frosts up in operation, check antifreeze level and circulation through the vaporizer body.
it is far simpler to replace the units than to rebuild them, though i have had success doing so. it depends on the labour rate and parts costs in your area.
mixer related faults may vary depending on what mixer you have but the model J and VFF30 symptoms are fairly universal and easy to diagnose. i do not like model K or Cobra units as the pin seat frets at the housing and they do not take rebuilds as well as the J units.
  • Posted 6 Mar 2009 10:09
  • Modified 6 Mar 2009 10:11 by poster
  • By steponmebbbboom
Hello! I also noted this old post on impco training from drlifttruck and I would like to have a copy of this material in the PDF format which can be emailed. Pretty please, email me at bbideau at beachner dot com or brianbideau at yahoo dot com.
  • Posted 2 Jan 2009 00:54
  • By manstihl
  • joined 2 Jan'09 - 1 message
  • Kansas, United States
Well heck fellas. I'm here in the USA. I can still buy & sell the old model J's. I can get anything ya want on them.
  • Posted 15 Oct 2008 14:31
  • By lildog1973
  • joined 15 Oct'08 - 3 messages
I saw this old post on impco training from drlifttruck and I was wondering if it wouldn't be too much trouble if I could possible get a copy of that. Please email me at mickpo at verizon dot net
  • Posted 25 Sep 2008 10:12
  • Modified 25 Sep 2008 10:13 by poster
  • By mickpo
  • joined 25 Sep'08 - 1 message
No Problem,
Email me at ulsh1 at AOL Dot Com
  • Posted 8 May 2008 14:17
  • By Drlifttruck
  • joined 20 Nov'05 - 106 messages
Lift Trucks all the same, just painted different colors.
Doc
Email: kulsh@forkliftservice.net
Hi, I'm new here and I saw this old post on impco training from drlifttruck and I was wondering if it wouldn't be too much trouble if I could possible get a copy of that. We have several fork trucks at work that have the model j converter set up, and one of them is not running right. Thanks.
  • Posted 8 May 2008 10:28
  • By brotherbob
  • joined 8 May'08 - 1 message
  • Virginia, United States
Glad I could help Dave.
Just to add on to the above I have just remembered that at the same time the fuel feed pipe from the fuelock to the converter (Pigtail pipe) was also changed in length.
The change in pipe length was to reduce the amount of LPG that could be in the lines and possibly force its way into the cylinders (If I remember correctly) and this also meant that the units had to be moved closer together....so you may have seen this change as well.
  • Posted 28 Sep 2006 20:15
  • By daniel_g
  • joined 13 Jan'06 - 83 messages
  • Flevoland, Netherlands
I have acess to IMPCO training in PDF format, from the year 2003 if you would like contact me at my address
  • Posted 24 Sep 2006 09:00
  • By Drlifttruck
Doc
Daniel, Thanks for the explanation. That is really great! you have filled in all of the "grey" areas for me. What you say about the primer shroud and the German market now makes sense! I have seen the shroud on trucks built by Clark in Mulheim in the past and currently see the same on Toyota from Ansenise France. But product built in Italy (BT Cesab) has no shroud. We buy parts from HKL and find them very helpfull, but they could not answer my question anywhere near as well as you have done. Dave
  • Posted 22 Aug 2006 19:23
  • By DaveUK
Dave,
The story you have heard of the accident in Germany is kind of true, but is a lot more complicated than probably anybody would like to understand.
The story goes that the operator over time had got into the habit of pushing the primer button whilst cranking over the machine, instead of priming first and then cranking, and this led to the metal plate which the primer contacts on the Diaphragm to bend. With the plate bent the gas pressure could force the valve off of its seat and gas could flow to the engine, with the ignition in the ON position one would guess.
The operator then one morning does his usual and bends over the engine pressing the primer and starts cranking where by he gets a nasty little surprise from the igniting of the gas stored in the cylinders and lines.
There were a number of other factors that caused the accident as I understand it and the converter problem was given as a probable contributory factor on the back of which new German regulations were introduced. The first part being that an operator should not be able to prime the system manually (i.e. they shouldn't be able to bend anything), and the second being that on an annual basis every LPG converter should be stripped and components replaced, without exception.
The Cobra is as stated an updated K with the addition of the locating holes on the casing for the primer cover and I believe the slight change of the internal components with the increase in strength of the plate that the primer button contacts. With very minor changes to the K model Impco could satisfy the German legal requirements and continue to use one converter for all markets, which is why we all have the Cobra (One type suits all).
The UK has no regulation regarding the primer cover, and the only market that needed it as a legal requirement was Germany and so as Dutch manufacturer we only supplied them on machines shipped into Germany, but I can imagine German manufacturers may have had them installed on all units.
When I was still working in the UK I found HKL Gaspower very good when it came to questions about the Impco product, so if you need more info you can find them on the web.
  • Posted 17 Aug 2006 19:43
  • Modified 17 Aug 2006 19:51 by poster
  • By daniel_g
Sorry, can't help you on the drawings...
Looked everywhere, and like you, only found drawings of j's and k's
The only explanation I come up with for the lack of a primer button is that it's cheaper to make.
Cobras are available with primers as well.
Impco classified the primer as a diagnostic tool, and thinks that it's no longer required...
As for the schreider valves: I've never seen that, so i doubt that it's an Impco item. We just plumb guages into the ports for testing.
  • Posted 8 Jun 2006 00:37
  • By mike_n
  • Alberta, Canada
Hi Mike Yes we do the same with lock offs and vaporisers, it costs too much in time to fit the kits. Some things I would like to know: Why has the button been removed on Cobra? It also used to have a plastic cover, what are the rules if it gets lost?
We see on some vapourisers, Schreider valves on the primary and secondary chambers, do Impco supply a pressure gauge to suit this type of valve? Do you know where I can get an explanation or cut away drawings that refer to Cobra and not the old K and J's. From what I can see the only internal change is to the Primary chamber valve. It used to be a flat spring with a rubber face valve. Now the valve has a "stem" with a rubber seat on the end. My drawings show the K's spring seat. I just think Impco must have updated the information somewhere. Then I coulld give up to date information to my technicians.
Even the lock off's show the "O" ring seal on the valve stem, yet it has had a "U" ring seal for years!
  • Posted 31 May 2006 06:35
  • By DaveUK
I'm still not sure exactly what info you are looking for.
The cobra is just an updated K, works exactly the same. They changed materials and did some slight design modifications inside.
From what I can tell, it was done simply because the original patent ran out. Just before the cobra's came out, a whole wack of knock-offs appeared on the market.
We don't kit lock-offs or vapourizers any more. It's cheaper to just replace the whole thing because of labour.
  • Posted 30 May 2006 23:51
  • By mike_n
  • Alberta, Canada
Hi Toric, I probably am as old as you! I've been working on FLT's for the same company 33 years. I do seem to remember Con liked his liquid lunch, so must be the same guy you remember
  • Posted 30 May 2006 04:30
  • By DaveUK
you must be as old as me
was Con Hanlon the big guy that preferd the liquid lunch if so i rember him.
  • Posted 27 May 2006 13:50
  • By Toric
  • joined 21 Jul'05 - 9 messages
  • lothian, United Kingdom
Hi Frankie, I'm looking for any up to date information on Impco including Cobra. I can't really talk to Barlow as I work for their major competitor in the UK. We dont have any serious legislation for emmissions. Closed loop systems are on about 10% of the units we sell. (Commander or ECS) We just have to have proof of training for our Techs. records for Health and Safety! The only info I have refer to K and J units or the little books you get with the repair kits which are too small to scan. So anything you have would be gratefully reiceved. I think I can put my e-mail in my profile so if you click on it you should be OK............I,m new to the forum so don't know if this will work. If not maybe the administrator will tell me a way round it.
Thanks Dave
  • Posted 27 May 2006 01:21
  • By DaveUK
Dave.
What Information Exactly are you looking for. Over here in Canada you have to have a liciense for everything especially gas.
Impco have done away with the model J it was replaced by the model K which had major problems with the pin in the centre.
Model K was Replaced by the Cobra, presently in use here.
Now with the introduction of latest generation lift trucks they have got real mean on Emmissions using closed loop systems etc - etc.
Try a Reputable lift truck company like Barlows they are the Hyster Dealer in your area for your info if you have no luck give me a buzz & i will find what you need & send it to you.
[email address removed]
  • Posted 25 May 2006 15:20
  • By FrankieW
  • joined 25 May'06 - 22 messages
  • British Columbia, Canada
rodger, thanks for the Impco web address. I have found that one in the past. It doesn't really give me any tech info on Impco stuff. The only training or tech information seems to be a link for a colege in the US..............I won't get that trip past my boss! I feel I need to update my knowlege on LPG fuel systems as the last formal training I had was with Calor Gas in the UK.............a really good guy called Con Hanlon used to run the training. Some of the UK guys in the forum may remember him. Where is he now...........I think he was close to retiring in the mid 90's when I new him. I still use a Video tape that Calor produced, but it is well out of date. regards dave
  • Posted 14 May 2006 18:09
  • By DaveUK
Unicarriers FHGE35T5S
Terberg YT222
Terberg YT222
