EV100 problems
This is a older EV100T1 control in a Clark TM20 forklift. The customer says the positive battery cable burnt off the battery and they put a screw in it to reattach it. After that the truck would jump to full speed when first touching the throttle. Then they called me. I fixed the cable properly then I found the 1 rec was shorted so I put a new one in. It didn't cure the jumping and I determined that the 1 rec was turning on and but not turning off. Long story short, I had new 2 and 5 recs with me so I put them in also, no differance. Tried a new card, no difference. After fiddling with it a bit, I noticed that the capacitor was charging up as soon as I pluged in the battery, even without trying to run it. Any ideas?, transformer or 1X choke bad? One thing I also noticed is it takes 3 trys on the throttle before the card shuts down and has to be reset with the key switch and the contactors never shut down even though the controler has PMT. Thanks for any help.
  • Posted 20 Feb 2010 08:07
  • Modified 20 Feb 2010 08:08 by poster
Did you check the throttle with a volt meter? If memory servers me right you should show +/- 5 % fully depressed.
Sounds like the customer has a bad battery to burn off the positive cable.
Good luck!
  • Posted 20 Feb 2010 20:40
  • By Lance
  • joined 20 Feb'10 - 3 messages
  • Colorado, United States
Treat others with respect and collect reward points
Toyota 02-8FD25
Mitsubishi FGE35AT
