display
after charging overnight display reads full 100% after a couple of hours the display is blinking but the battery reads 36.8 on a meter would the display send a signal to the controller to lock out the lift thanks for your help, mike
  • Posted 29 Nov 2009 02:30
  • By squidman
  • joined 12 Mar'08 - 23 messages
  • Rhode Island, United States
oneshotmech@yahoo.com
I don't suggest trying to check the battery while traveling, that has a tendency to have someone look away from the direction of travel, just long enough to eventually cause a real serious problem, and lifting to a "stall" puts more of a load on the battery than traveling.
I also use a 10% rule as to voltage drop, which, as we see more and more higher voltage batteries in the USA, will make a difference in the troubleshooting. if it drops 10% from the "at rest" voltage, then fixing the battery problem is the needed first step.
  • Posted 23 Dec 2009 00:26
ive had batterys read voltage but underload they dropp over 5 volts due to bad cells in batts
meter the batt w/ a fluke while lifting and traveling tocheck voltage drop more than 3 might be a bad batt
  • Posted 22 Dec 2009 11:10
  • By manny
  • joined 22 Dec'09 - 9 messages
What is the voltage, at rest, 5 minutes of operation after you take it off an overnight charge? What is the voltage when you stall the hydraulics?
Fill the battery with water, and confirm (not just run the automagic filler, but look in each cell) charge battery 8 hours and allow to cool 8 hours.
What is the voltage at rest, and then what is the voltage when the hydraulics are stalled all the way up.
Your battery meter readings and lift cutout are common symptoms of a battery with a few dry cells, maybe from an automagic watering system that is stuck and not allowing water into some cells, (or 1 cell), or has some other battery problem.
the next test if these do not show anything would be taking a specific gravity reading on each cell with the battery pretty much fully charged.
Your battery may read a full charge, and then go down that quickly, if it was only getting a 1 hour charge. We call that a "surface charge", so you may want to confirm that the charger really is running 8 hours a night, and not getting shut down when the last person leaves in the evening.
  • Posted 29 Nov 2009 05:48
  • Modified 30 Nov 2009 01:00 by poster
Briefs United States
Toyota 8FD45
Airman ENCL045
