Troubles with lift hoses C30L
I'm reparing a C30L, the problem is with lift hoses, the tower has this serial number: 45dmq8860 0001M 2807290, We change the hoses every two or three weeks. When the tower goes up or down the hoses moves out the hose reels and they pass around the gears located in the midle of the tower, then we look... and the hoses have an oil leak. I want to know if the tower has manufactured defects or...if you know what can i do to make work the reels and the hoses property?
  • Posted 28 Oct 2009 03:12
  • Modified 28 Oct 2009 03:18 by poster
  • By azucena_v
  • joined 28 Oct'09 - 23 messages
  • Mexico City, Mexico
THAKS AZU_VAZ@YAHOO.COM.MX
Not real familar, but if the hoses screw into the tower, could the tower have a seal leak?
  • Posted 22 May 2015 10:48
  • By edward_m
  • joined 11 May'15 - 111 messages
Yeap... We have already cheked if the hoses were twisted, and... they didn't , we have used 2 wrenches. And... can you tell me what's the correct thickness for the hoses? because... we always have been working with the same thickness.
  • Posted 29 Oct 2009 10:38
  • By azucena_v
Hello azucena v, Make sure your hose are not twisted. It usually happens when you tighten the fitting without 2 wrenches. Also make sure you have the proper hose thickness. It won't fit into the sheaves properly if to large.
  • Posted 28 Oct 2009 22:29
  • By Prentice
edition #1257 - 20 November 2025
