TOYOTA 7FBMF18 AC
Hello,
I've a problem with a 7FBMF18 with AC motor. The truck run slow without any error code in display.
Could anybody help me?
thanks in advance
Regards.
  • Posted 26 Sep 2009 21:39
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Look after your signal off bearing off drive motor look in Monitor menu.
Ore signal by scoop !!!
John.
  • Posted 30 Oct 2009 06:41
  • By johngen
  • NB, Netherlands
thanks to all people for the help.
The problem has been solve, replacing the encoder drive motor.
Thank you.
Regards
  • Posted 26 Oct 2009 07:39
  • By nacsand_n
  • Madrid, Spain
The fault almost certainly lies in the CPU.
You can try to replace it, otherwise it is a defect in a weld in the group of power IN-MOTION.
Greetings - Franco --
  • Posted 25 Oct 2009 08:12
  • Modified 25 Oct 2009 08:15 by poster
  • By franco_c
  • joined 28 Jun'09 - 25 messages
  • Bologna, Italy
Ok, I'll try to check the footpedal output.
I'll tell you.
Thank you very much for your help.
Best regards
  • Posted 28 Sep 2009 02:58
  • By nacsand_n
  • Madrid, Spain
If i was to guess I would say either its a mechanical related issue perhaps or somehow related to your accelerator. If someone has the information perhaps they may know what the footpedal output should be at maximum sweep. Just out of curiosity what voltage wipe do you get at your accelerator unit?
  • Posted 27 Sep 2009 21:25
  • By elektrodrive
The speed is correctly programmed, but the truck runs slow, there is no faults in display. I´ve changed the encoder sensor of traction motor, but also runs in the same way.
What do you think about it?
Thanks a lot for your anwers.
Best regards.
  • Posted 27 Sep 2009 07:22
  • Modified 27 Sep 2009 07:22 by poster
  • By nacsand_n
  • Madrid, Spain
Has the truck suddenly developed this fault? Or is this a truck you have bought which just happens to be running slow?
The reason I ask is, incase it has been programmed to run at a slow speed.
  • Posted 27 Sep 2009 06:51
  • By elektrodrive
Mitsubishi FGE35AT
TCM FHD105Z
