Linde H30D Problem
I am being haunted by a Linde H30D (S/N H2X393S01476), it seems to have an electrical problem. The symptoms are, when a directional pedal is pressed it throttles up and starts to move and the further down the pedal is depressed it starts to slow down and eventually stop without engine rpm loss, (seems the engine does not accelerate fully either), also seems that the throttle "hangs" when the either pedal is depressed fully and released for about 4-5 seconds, and last most, the glow plug indicator is flashing (all glow plugs check ok). A small bit of history on this, about March of this year, it threw the timing belt and damaged a bucket type lifter (amazingly no other damage) replaced the timing belt and lifter ran like new. about 2 months later it came back in smoking like mad and did compression check, it was low, but seemed to run ok, replaced the rings, bearings, head gasket, and rebuilt the turbo...this is when all the problems started, checked all that I could find and think of, grounds, connectors, ect. There were 2 Linde techs that hooked it up to Truck Doctor and such...couldn't find anything wrong system wise. Anyone have any idea on what could be going on here...before I lose the rest of my hair!
  • Posted 15 Aug 2009 01:59
  • Modified 15 Aug 2009 03:48 by poster
  • By dan_k
  • joined 12 Jul'08 - 1 message
  • Wisconsin, United States
dan k,
i had just this problem (apart from glow lamp flashing) when i was working for Linde.
it took a few days and too much testing to believe.
replace No 3 injector (one with wire) dont try for overhaul as i went down that line thinking i was covering every possibility.
this was the problem, new injector and ran perfect.
the glow lamp flahing indicates engine management problem, but it could just be picking up faulty injector.
part number for injector is VW038130201R and they are available from local VW garage at half Linde price (in UK!!)
  • Posted 15 Aug 2009 06:01
  • By ian_h
  • joined 11 Sep'08 - 149 messages
  • United Kingdom
if i can help i will.
