see saw effect
weight -distance-force
To be honest im not the best at explaining this. If any1 has some info regarding this or links to a site would be gratefull, thanks...
  • Posted 20 Jun 2009 04:21
  • Modified 20 Jun 2009 04:24 by poster
  • By ZZJASEZZ
  • joined 15 Mar'08 - 73 messages
  • BUCKINGHAMSHIRE, United Kingdom
RTITB F.L.T/MHE INSTRUCTOR/MANUAL HANDLING INSTRUCTOR.
Showing items 1 - 17 of 17 results.
Dan,
I'm sorry to have taken sooooooo long to reply but I've been flat out like a lizard drinking.
My email address is burnspatb @ yahoo "dot' com "dot" au.
Regards
Pat
  • Posted 9 Oct 2009 06:58
  • By paddyB
  • joined 23 Apr'09 - 51 messages
  • Queensland, Australia
In 20 years time people will regret what they didn't do rather than what they did.
contom@wsinc(dot)com
Thanks
  • Posted 5 Aug 2009 01:02
  • Modified 5 Aug 2009 01:02 by poster
  • By TC17
  • joined 17 Apr'08 - 53 messages
  • Wisconsin, United States
Need an email address. Also, this portion of my PowerPoint is not for distribution over the internet, and any use of these slides should be confirmed with me first. Basically, for your eyes only. Thanks.
  • Posted 5 Aug 2009 00:57
  • By dan_m
  • joined 14 Oct'05 - 335 messages
Dan, is it possible to send a copy of the power point to me also, I would like to review it
  • Posted 4 Aug 2009 23:56
  • By TC17
Wisconsin, USA
"Be safe"
Sent.
  • Posted 1 Aug 2009 23:37
  • By dan_m
hey dan would love to have that info...could u please email me at elevadora(at)gmail.com...
cheers
  • Posted 1 Aug 2009 22:23
  • By t_lift
  • joined 7 Jan'09 - 11 messages
  • dubai, United Arab Emirates
PADDY,
DONT HAVE UR EMAIL ADDRESS
  • Posted 30 Jul 2009 14:06
  • By dan_m
That is you email at the bottom of your comment?
See it!
Try tonight or tomorrow AM with my comments for each slide as I deliver it to my students
  • Posted 30 Jul 2009 08:23
  • Modified 30 Jul 2009 08:26 by poster
  • By dan_m
Pat, you can add your e-mail to your profile, and that way if anyone clicks on the name, they can get your e-mail address (and it keeps "spam harvster bots" from getting your mail by automagically reading the forums).
In order to "get it through the thickness" I always offer up; "Remember on the playground, that if you have a pork-chop kid and stick kid you can put the stick kid right up next to the middle of the teeter-toter and the pork-chop kid at the end" and when they nod in agreement I say "NO, that is exactly wrong, you put the skinny kid on the far out end and the pork-chop kid close to the middle pipe, and we say that as 'weight+distance equals balance or moment', which is 'the principal of balance' which is the way forklifts are designed".
AND, Dan, can you e-mail me that powerpoint too?
My mother wrote advertising so I grew up in a family were we didn't use "Fat" or "Skinny" to describe a person's figure.
  • Posted 30 Jul 2009 08:01
  • Modified 30 Jul 2009 08:06 by poster
Cascades website has a link that calculates any forklifts downrate and takes into account all your variables, (Distance from axle--attachment weight--forklength and slope to tip etc.) Its set up in a formattable Excel form so you can change all the parameters and save it to file on your computer.
  • Posted 30 Jul 2009 07:55
  • Modified 30 Jul 2009 07:58 by poster
  • By chublil
  • joined 28 Jul'09 - 187 messages
Fix it right!!!
Dan,
would it be possible to send me the powerpoint pres as well.
(am i allowed to put my email address on the forum??)
Regards
PAT
  • Posted 30 Jul 2009 07:41
  • By paddyB
ZZ,
Give me your email address. I will forward you the PowerPoint slides pertaining to the lever principle and how I explain it
Danny
  • Posted 26 Jun 2009 12:24
  • By dan_m
You`ve lost me there John think i will take onboard your previous post
  • Posted 22 Jun 2009 06:15
  • By ZZJASEZZ
ZZJASEZZ,
As they say "U R Spot On" - Good student - quick learner.
Remember in a lift truck application teh net lift capacity of a unit can be limited by factors other than simple match or ft - in calculations. Items such as: fork limitatations, especially at load centers signifcantly beyond (say beyond 30" load centers) the 20" (500 mm) or 24" (600 mm) load center - often a larger fork section must be used, tilt cylinder limits, carriage bar /roller limits, mast channel limits (especially the flanges), tire capacity limits, hydraulic system, etc These factors can only be determined by the fork lift manufactuer.
Good Training!
  • Posted 22 Jun 2009 06:11
  • By johnr_j
  • joined 3 Jun'06 - 1,452 messages
"Have An Exceptional Day!"
re johnr
A 50 lb. person sitting at the other end of the see saw sitting at 4 feet from the balance point will create the same force and both persons will be in perfect balance. The math 50 lbs. x 4" = 200 lbs. ft.
2.) If the 50 ponder moves 6 feet away from the balance point he will create a greater force (or 300 lb.- ft.) and raise the larger person in the air.
This will help thanks...
  • Posted 21 Jun 2009 20:18
  • By ZZJASEZZ
A simple explanation might be weight (or mass) acting through a distance (inches, centimeters, etc) creates a force.
Examples:
1.) On a see saw (or teeter-totter) a 100 lb person sitting a 2' from the balance point (or fulcrum) will create a force of 200 lbs.- ft (often and very incorrectly stated as ft-lbs*) match 100 lbs x 2 feet= 200 lb.-ft). A 50 lb. person sitting at the other end of the see saw sitting at 4 feet from the balance point will create the same force and both persons will be in perfect balance. The math 50 lbs. x 4" = 200 lbs. ft.
* Yes this is a fact. As they say I are an engineer by degree. Also, a battery sitting on concrete will not discharge any faster than a battery stored on wood, plastic, cardboard, etc. They both will discharge at the same rate. Concrete is not a conductor of electricity but humidity in the air is. Batteries from little lawn tractor batteries to forklift 1200 am/hr batteries are recommended to be charged at least every 6 months if not put into service to 1.) boost voltage to spec 2.) add water that may have evaporated below the top of the plates 3.) to prevent plate sulfating
  • Posted 20 Jun 2009 07:23
  • By johnr_j
THE FORKLIFT WORKS ON THE PRINCIPLE OF LOADS BALANCED OVER A FULCRUM.
A SIMPLE EXAMPLE OF A FULCRUM IS A SEE-SAW OR TEETER-TOTTER.
A POINT IN THE EXACT MIDDLE WILL BALANCE THE EQUAL WEIGHTS AT THE ENDS.
THE FULCRUM OF A LOADED TRUCK IS A IMAGINARY VERTICAL LINE THROUGH THE CENTER OF THE DRIVE AXLE HUB.
Not sure if thats where you were going, if I had a marker board I got another couple hours left in me...but then we would all be asleep by then.
Sorry for the shouting, easier to for the old guys that need glasses.
  • Posted 20 Jun 2009 05:45
  • By TradeShowDave
  • joined 14 Mar'09 - 48 messages
Jim Tompkins Jim Tompkins
Sales operations, Heli
F. Uchiyama
Taylor TT300
Manitou M50-4
