SSP sideloader
A customer of mine has an SSP sideloader, which apparently has had a replacement engine in, its a ford but not sure which model. There was a plate in the engine bay. But the details don't look like a ford engine model. They are; 823F 6AAA 26/D/83 A. Any help would be appreicated.
  • Posted 24 Feb 2009 02:50
  • By Leon_W
  • Tyne & Wear, United Kingdom
could well be a 2711e if not go to a good specialist engine rebuild company - they should be able to tell from the numbers -there used to be a n exellent one in the selby region they always used to advertise in the auto trader
  • Posted 26 Feb 2009 19:24
  • By iain_w
  • joined 19 Feb'09 - 18 messages
  • CHESHIRE, United Kingdom
nothing wrong at the minute, just trying to source the parts for the service. Spoke to SSP and i think we have worked out what engine it is. Although it says ford, it has been rebuilt by SSP ta some time and a different type engine fitted. Parts are ordered. Thanks you your help anyway kevin.
  • Posted 25 Feb 2009 06:00
  • By Leon_W
is it an old machine ??. are the injectors inside the rocker cover ,if so it,ll be the same engine as an old ford D series lorry. they had a paper cartridge filter on them. hendy ford power products were quite helpful if i mind right. you should be able to get parts from them. whats wrong with it ?
  • Posted 25 Feb 2009 04:26
  • By kevin_k
Already spoke to them kevin. Thats how i found out that it had the wrong engine in. Apparently it should have a screw on oil filter. But it has a cartridge type filter.
  • Posted 24 Feb 2009 07:41
  • By Leon_W
ssp are built in barnsley area. give them a bell. only a little company they should be able to sort you out leon. they have a website too mate
  • Posted 24 Feb 2009 06:24
  • By kevin_k
