No power
The batteries seem fine. I'm getting over 25 volts. The controller is doing the single flash every couple seconds. I can see the Amber light go on when I move the tiller down some and go off when it's all the way down. What I don't see is anything on the screen. No beep. It has power, now I'm wondering if there's something wrong with the tiller. I'm running out of ideas.
I wish I could get my hands on the wiring diagram.
  • Posted 21 May 2025 10:03
  • By JBDragon
  • joined 23 Aug'18 - 15 messages
Did for some reason the tiller get wet? Remove it and check for corrosion. Second is the tiller cable has a potential to crack and or break wiring. Ohm out the harness from pivot point to tiller connection. 4 wires.
Any green on the tiller e-tac card it must be replaced.
Earlier models were prone to have the lithium battery go dead on the tiller card also. Needs to be at least 3.0 volts. You can replace that battery with a 2016 lithium button battery. Remove the top and bottom flaps to the button battery carefully. Then rough up the surface with emery cloth. Soldier them back on to the new battery. May have to download new software.... But Try it first if you have to replace the battery. That card is expensive and for 10$ you can replace that battery yourself.
  • Posted 23 May 2025 12:18
  • By ron_k
  • joined 2 Apr'15 - 124 messages
  • North Dakota, United States
4kliftman
Manitou MH25-4
Nagano NUL120-6
Manitou MH25-4
Nagano NUL120-6
Sue Tomic Sue Tomic
