no crank , starts when bypassed
hello all , I have a 7fgcu32 with a no crank issue if someone could Please share the starter circuit diagram I can resolve the issue
here is what I have done : battery is perfect and holds load test , starter is good , starter relay is good , at the starter relay i have battery voltage on 2 legs and ground on 2 (normal) however when applying the key i lose the ground from 1 leg i can watch it go down on a volt meter as though there s a bad contact or short somewhere.. i have also checked the neutral switch in the shift stock and confirmed it works , also confirmed the ground loss is occuring there as well , i am not sure where the wire goes and dont want to just throw parts at it
  • Posted 1 Apr 2025 02:54
  • By david_le
  • joined 1 Apr'25 - 2 messages
I remember there were some problems with the wiring, above the oilfilter there is a bundle of wires, open them up, there should be a connector with 2 wires, the connector is not used but 1 of the wires could be broken.
The connector is between the second and third cylinder sparkplugs.
  • Posted 14 May 2025 06:53
  • By John50
  • joined 7 Sep'19 - 153 messages
  • Netherlands
I guess no one can help!
  • Posted 9 May 2025 23:18
  • By david_le
Sue Tomic Sue Tomic
Taylor TX330S
USD159,500
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
