unit doesnt run
Hi, i recently started working on 2 yale mpb045gn walkie units. they had been sitting for a few years with no batteries in them. i installed some new batteries, and when i power the trucks up they both exhibit the same symptoms, the horn blows as soon as you key it, and on one unit nothing functions, and the 2nd unit it runs the lift pump regardless if i push lift or lower buttons. the chargers on each truck also dont turn on, and just flash the leds on the plugin port.
my thought is the programing for the control head cards is no longer there, but i wasnt able able to get the cards to respond to programing or learning by moving the jumper. one of them eventually displayed a flt30106 code. im stumped at this point. any ideas? thank you
  • Posted 13 Dec 2023 03:44
  • By kevin_jones
  • joined 13 Dec'23 - 1 message
  • Arizona, United States
are there two small wires from the charger at the SB connector. If so follow the wires to the key switch. Should be male female red connectors. Unplug the wires and reverse the connection. This will bypass the charger Hope this helps
  • Posted 31 Dec 2023 02:38
  • By forkliftpete
  • joined 19 Nov'14 - 24 messages
Pete
Yale Lift Truck Technologies
Nagano NUZ090D
UN Forklift FL20-32LNJX2
