No display on access one
PC 4500 has no display on access one. Access one in another truck and it comes on. Any ideas on what powers access one display. When turned on the truck this slowly beeps
  • Posted 20 Jul 2023 00:51
  • By BigAl88246
  • joined 5 Apr'17 - 11 messages
Exactly , the problem is in access1 module. In case if the warrantly is gone for your module , you can simple open it and try to troubleshoot. There are two level of boards , like a pie , and one with flat cablle , comming from the bottoms , as I remember.
Especially , pay an attemtion to disconnect that flat cable. Tnen , using magnifier lamp , inspect outer board , where are located PWM power supplies chips which provided power for processor , periphery and also for disply indicators. I'm pretty sure , you will find something burned down.
Good luck with the findings !
  • Posted 20 Jul 2023 05:20
  • Modified 20 Jul 2023 05:23 by poster
  • By Slav
  • joined 23 Jun'23 - 10 messages
  • Turkmenistan
serov.tm@gmail.com
If you tried a diffrent access 1 and it worked, i recommend replacing the whole access 1. It sounds like a part of the board in the access 1 was damaged, the beep would represent an error with the access 1 module.
  • Posted 20 Jul 2023 00:55
  • By DyslexicNerd_01
  • Wisconsin, United States
VETTER Forks, Inc.
Maxlion FB25EH
Unicarriers FHGE35T5S
VETTER Forks, Inc.
