Starts and runs for a few seconds then dies
It starts and runs for a few seconds then dies once and a while it will start and run fine and revup then it will die after that sometimes it will fire right back up then it won't at all I've changed the lp regular checked and cleaned the filter tune up replaced the battery all fluids are full changed the map sensor and throttle position
sensor I've been fighting this thing for 2 months the customer wants there pos back
  • Posted 30 Jun 2023 01:43
  • By Nick_Johnson
  • joined 22 Apr'23 - 2 messages
  • Illinois, United States
place a 200psi gauge between the lpg tank and the twist connector, you should see between 100-145 psi and see if it drops off when it does run, i know a lot of people accidently double seal the twist connector at the bottle.
  • Posted 11 Jul 2023 04:18
  • By mel_everest
  • joined 26 Mar'23 - 4 messages
  • United Kingdom
Sue Tomic Sue Tomic
