Mast wont rise or fall
Hi
I have been having intermittent issues with my mast, it will rise and fall for a while then stops working, I have to switch off the ignition and restart (this is a battery operated unit)
Is there a self latching relay that controls this function?
Any ideas what it might be?
Chris
  • Posted 17 Nov 2022 01:29
  • By Chris_Davenport
  • joined 17 Nov'22 - 3 messages
  • United Kingdom
Chris Davenport
I think you have a coil piece on the valve block
the easiest is laptop on it
  • Posted 30 Jan 2023 03:13
  • By michel_v
  • noord holland, Netherlands
Ok thanks for that much appreciated
  • Posted 29 Jan 2023 21:55
  • United Kingdom
Chris Davenport
Sorry Chris just seen your reply. Without plugging in a laptop and checking the error codes it's hard to know but it is more than likely the joystick which is faulting up this is a very common fault on all Linde trucks
  • Posted 29 Jan 2023 21:37
  • By lifter01
  • joined 4 Jul'09 - 463 messages
Hi,
Type: E30-02
S/#: G1X336L00305 / 2000
Rated: 3000kg
80 volt
Lansing Linde Ltd GB - Basingstoke
  • Posted 24 Nov 2022 22:22
  • United Kingdom
Chris Davenport
We need the serial number to help it could be many things post the serial number and we should be able to give you a better idea
  • Posted 19 Nov 2022 06:32
  • By lifter01
Tusk 500PGH14
Crown CG33P5
Tusk 500PGH14
Crown CG33P5
Combilift Ltd
