transmission oil spillage through the dip stick tube and even blows off transmission filter
old model hyster forklift.... please can somebody show me where the transmission breather is.....and how to solve my problem thanks......
  • Posted 25 Jun 2022 19:30
  • By northstar
  • joined 16 Jun'17 - 92 messages
  • accra, Ghana
Glad to be able to help it is a common problem on Both the XL and XM models
  • Posted 7 Jul 2022 07:45
  • By lifter01
  • joined 4 Jul'09 - 463 messages
thanks, u saved us time and money, we detected inferior filter.....
  • Posted 4 Jul 2022 00:12
  • By northstar
  • accra, Ghana
Some had a pipe that went from the transmission top to the transmission filler tube which are prone to blocking. If not changing the transmission filter usually cures this I've had lots doing it in the past, make sure you use original filters and JD40 spec transmission oil not red dexron 2 atf
  • Posted 3 Jul 2022 07:52
  • By lifter01
