no start after sitting a while after warmed up
sorry don't have the model number at the moment... My propane forklift will start fine and run as long as needed. Shut it off and right away it starts right up again. Let it rest there off for 10 minutes or so and it won't start again till it cools down. I installed a new regulator. It's radiator is full. The reg is getting hot water through it. Full tank and in right position. Has liquid propane into the vacuum cutoff. It will crank during this time but it kinda backfires a bit while cranking. Like I said let it rest a good long while and it will start right up and idle great.
  • Posted 22 Jun 2022 14:00
  • By Joe_M
  • joined 11 May'21 - 6 messages
When it doesn't start is it getting good spark possible you have a bad coil inside distubister better to install complete unit. l only say that because you said it backfires when cranking sounds like ignition problem.
  • Posted 25 Jun 2022 09:15
  • By Scott_
Scott
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Maxlion FB35EH
F. Uchiyama
USD1
Maxlion FB35EH
F. Uchiyama
Michel Denis Michel Denis
