Truck not powering up
Hi
Truck won't put dash on, only battery meter
Only steering works
Plug computer in for Linde software but canbox doesn't get power from the truck
Please advise
  • Posted 26 May 2022 20:24
  • By Peter_Hughes
  • joined 26 May'22 - 5 messages
  • Ireland
PD Lift Trucks
Can I suggest something to try
This used to happen at the factory when we built these
Turn the ignition on
Pop the display out of the cover and unplug the display then reconnect it whilst the key is still in on position
  • Posted 16 Jun 2022 19:38
  • By Lindetechnz
  • joined 28 Apr'21 - 58 messages
  • New Zealand
Lindetechnz
Hi did u sort this problem
Out?
  • Posted 10 Jun 2022 01:39
  • By Lindetechnz
  • New Zealand
Lindetechnz
I think Fritz is right
  • Posted 1 Jun 2022 03:59
  • By michel_v
  • noord holland, Netherlands
check the 24volt dc for controllers , voltage on can also check. battery meter are the battery voltage, so i think missing 24 volt circuit
  • Posted 31 May 2022 23:55
  • By tr_doctor
  • joined 4 Dec'20 - 186 messages
  • Netherlands
Regards
IIRC the canbox feed is from the drive controller, that flat box with two large connectors. I'm afraid that needs to get replaced.
  • Posted 28 May 2022 04:41
  • By frits_f
  • joined 19 Dec'09 - 320 messages
  • utrechte, Netherlands
SMV (Konecranes) 12-1200B
Maxlion MTF30-45-2WD
Michel Denis Michel Denis
