Display working but restarts after pin entry
Dear all,
I bought a used Linde D12AP / 133 series
When it came, I entered the pin to start the machine (1234), it started, and after a millisecond it switch off and turned back to the PIN screen.
I tried with pathfinder, but Linde won't connect unless activated and KEY-ON.
This way I cannot work and it won't read the parameters and inputs.
I think its the Display Parameters for the NEXT SERVICE (Date or Hours) and they are both set to 0
How do I fix this?
What is the solution to bypass the display and set the parameters?
Thanks
BR
Filip
  • Posted 17 Feb 2022 02:54
  • By FilipMKD
  • joined 17 Feb'22 - 3 messages
  • Macedonia, The Former Yugoslav Republic Of
Filip Damjanovski
i have the same problem right now.
what did you end up doing?
  • Posted 13 Nov 2024 20:42
  • By MathiasBear
  • joined 13 Nov'24 - 1 message
  • Denmark
Mathias Bjørn
Denmark
Hello michel_V,
It's not the batterie, double-checked it and it has a perfect 24,5 V and 78% charge.
It's somewhere in the display and the problem is I cannot set the values of the parameters if the truck is not started.
  • Posted 18 Feb 2022 19:19
  • By FilipMKD
Filip Damjanovski
START CHECKING BATTERY POWER
i think the head contact is your problem
but install on key on it the wiring is all there
  • Posted 18 Feb 2022 17:46
  • Modified 20 Feb 2022 20:16 by poster
  • By michel_v
  • noord holland, Netherlands
Terberg YT222
Mitsubishi FGE35AT
