N492816
just wondering if someone has run across this problem
our old Yale not sure of year 1989ish
older ev panel no handset plug on card
new battery and forward/reverse switches exact same problem
place in forward will drive all day no problem
shift to reverse nothing no forward or reverse moving or not
cycle key on/off
select reverse drive all day no problem
shift to forward nothing no forward or reverse moving or not
cycle key
select forward or reverse and works but just wont switch when powered up with out even moving if you select forward then shift to reverse nothing
have to cycle key
anyone can gimme a hand id much appreciate it
3 repair companies have been into look at it including dealer money spent but none of them know for sure just want to swap parts
thanks guys
happy holidays
  • Posted 12 Dec 2021 02:21
  • Modified 12 Dec 2021 02:37 by poster
  • By Autodog
  • joined 27 Sep'12 - 12 messages
thanks for your help
i will update
  • Posted 17 Dec 2021 19:36
  • By Autodog
for the early model ev100's that did not have the Z plug for the handset there is a door in the front that flips down and there are trimpots there to make adjustments. All the other plugs are the same and provide the same function for inputs and outputs. The screw terminals also are the same. You can check the screw terminals with wires 6 and 8 for fwd and rev signal and see if the contactors are getting the signal from the card.
I believe in your other post you mentioned it comes and goes depending on when you cycle the key switch? I would do 2 things, first pull the plugs, get some needle nose pliers and go inside the plug on the card and tweak the pins slightly with a slight twist, this will insure they are connecting, sometimes they get loose and cause intermittent issues. The other thing is to check the fwd and reverse contactor tips and make sure they are not worn or binding.
You can replace the card with an updated one if you like but before you go through that check the card outputs first and adjust those pins as i mentioned above.
  • Posted 13 Dec 2021 17:12
I read your problem some old cards on ev100 had no way to plug handset into with made it difficulty to check you have to check each component. you could call a company called flight system give them the number of the card it is long number on the top of the card ask them if they have an up dated card with a spot to plug in handset. This would help were to start.
  • Posted 13 Dec 2021 03:02
  • By Scott_
Scott
Michel Denis Michel Denis
Aichi RX07B
Mitsubishi FGE35AT
Aichi RX07B
Mitsubishi FGE35AT
