No forward or reverse. A5FGL25-40041
Has a Computer Controlled transmission- CCT. Fault light on dash stays on after start-up. I have zero troubleshooting info on this lift. Trans # 33210-23102-71, 890002. Engine and hydraulics, no problems. The story I got was it ran and drove okay on gasoline, but the trans did act up - no f/r -, and they could tap on the carb throttle pos. sensor (generator?) and then the trans would start working. They converted it to an Impco propane system, now trans won't engage. They left the pedal position sensor plugged in and just hanging, and obviously the carb is totally disconnected. I tried pugging the carb back up, but that didn't help. help! lol
  • Posted 1 Dec 2021 07:39
  • By KOBrien
  • joined 18 Mar'20 - 12 messages
kwelectronics1@gmail.com
