Linde E14-02 tilt error 36)
Hey,
I have a Linde E14-02 (335) forklift, it has error 36 on (joystick tilt error).
The tilt function of the mast sometimes fails as a result.
I have read the tilt joystick, these are +/-14% sent out. If I install a new one, the problem remains the same. calibration doesn't work either.
If you switch off the machine from the ignition, it is just as good (0% control tilt joystick) after a few minutes this percentage starts to increase.
I have measured the wiring harness from joystick to controller, it is also good.
Does anyone have an idea where I should look for the problem?
  • Posted 24 Sep 2021 00:20
  • By Forklift123
  • joined 11 Feb'21 - 38 messages
  • Netherlands
Mechanic of Forklifts, Aerial platforms & telehandlers in the Netherlands
Hello....weard problem....maybe the controller is broken but before that i think you should take out the anti static....if u have gray tires problem will incrise. ground your lift truck with anti static strap and joystick pad too. (wire to frame)
  • Posted 27 Sep 2021 02:27
  • By Justus
  • joined 23 Aug'20 - 37 messages
  • Finland
Brussels Airport in Belgium, Europe is the world's largest sales point for chocolate, with over 800 tonnes of chocolate sold annually. This averages out to about 1.5 kilograms sold every minute.
XQ360 with SLAMXQ by Collective Intelligence Group
XQ360 with SLAMXQ
XQ360 with SLAMXQ
