Blank dash board display
Hello
Hyster H3.00FT dash board displays went blank when I started the machine one morning, screen back light comes on normal but written and fuel displays doesn't show at all.
But also Machine starts and operates normal.
Please can someone help me find out the fault.
  • Posted 2 Jun 2021 18:18
  • By Skytone
  • joined 2 Jun'21 - 4 messages
  • Ghana
Reuben.D
You got it
  • Posted 28 Jun 2021 01:10
  • By forkliftpete
  • joined 19 Nov'14 - 24 messages
Pete
Skytone,
Unless you have the correct program, you will not be able to program. If you move display from one truck to another, you can program with the correct files.
  • Posted 21 Jun 2021 21:59
  • By Fishmech
  • Virginia, United States
The ground to display is okay. I use a multimeter to check voltage to the display. I got 12v. I also check continuity of the ground wire to body and battery negative terminal, it was okay too.
Thank you.
  • Posted 21 Jun 2021 02:24
  • By Skytone
  • Ghana
Reuben.D
yes.
but first check ground to display too
  • Posted 21 Jun 2021 02:00
  • By shlomi_r
  • joined 14 Oct'14 - 21 messages
  • hchf, Italy
sglffy
Thank you Shlomi_r.
But to avoid too much cost can I buy new Display from factory and program it. Or there is no option than to change the vsm and DSC.
Thank you.
  • Posted 21 Jun 2021 01:58
  • By Skytone
  • Ghana
Reuben.D
no u cant switch between them.
only if u replace the vsm too
  • Posted 21 Jun 2021 01:44
  • By shlomi_r
  • hchf, Italy
sglffy
Thank you very much Fishmech, after checking, there is power to the display and all the fuses are okay.
Meaning the display has failed as you said.
So if I move one display to another , do I need to program the display?
Thank you
  • Posted 21 Jun 2021 00:48
  • By Skytone
  • Ghana
Reuben.D
Check all fuses in front of the battery, in the PDM. Remove top cover of the steer column, unplug display and check for battery voltage on the red wire. If all fuses are good and you have voltage, suspect display has failed. Does not happen often, once in a while. Do not move display from one truck to another as they are serial number specific. Thanks.
  • Posted 14 Jun 2021 23:59
  • By Fishmech
check for 12v to display
check fuses
  • Posted 5 Jun 2021 21:09
  • By shlomi_r
  • hchf, Italy
sglffy
Sue Tomic Sue Tomic
Aichi SR18A
Terberg RT403
Sue Tomic Sue Tomic
Aichi SR18A
Terberg RT403
