Fault E696
= Road speed abnormal update rate.
This is not a valid code for this lift..Is not in the fault list for this machine and this lift does not have any speed sensors.
Any ideas?? Thanks
  • Posted 25 May 2021 10:21
  • By JayR
  • joined 10 Nov'15 - 38 messages
Just saw this reply. You are correct! Had to have dealer reflash, problem solved. Some software snafu.
  • Posted 24 Jun 2021 06:14
  • By JayR
Jay,
This is an error that should not be. The lift will need to be programmed by your local dealer. If this does not work, may need to replace controller. Thanks.
  • Posted 18 Jun 2021 23:08
  • By Fishmech
  • Virginia, United States
Check Can high to ground minus, it must 2.5 volt
Check resistance Can hi and low are 60 ohms, if 120 ohm you have missing part or wiring
  • Posted 31 May 2021 03:31
  • By tr_doctor
  • joined 4 Dec'20 - 186 messages
  • Netherlands
Regards
Anything?
  • Posted 30 May 2021 00:21
  • By JayR
A380V04963S
  • Posted 26 May 2021 22:10
  • By JayR
serial number??
  • Posted 26 May 2021 00:47
  • By tr_doctor
  • Netherlands
Regards
Toyota 8FGC35U-BCS
Flesherton, Ontario, Canada
Taylor T650L
