Kubota diesel ECU replacement
Replaced the ECU on my 3.8L Kubota Hyster with DEF system due to no crank position sensor signal (after 3 sensors and a wiring check). Does this ECM need to be programmed by Hyster or should it learn from the VSM?
  • Posted 14 Mar 2021 03:00
  • By SWEnglert
  • joined 4 Dec'20 - 9 messages
Sue Tomic Sue Tomic
