Connecting a sideshifter to Vickers valve
Hello, mine is a Clark C500 Y40 PD (Y355-2826-GEF3966), to which I would like to fit a side-shifter and/or a bucket. As far as I can see, there is the Vickers valve already installed on the right hand, but no leverage and no fittings to the front. Only "In" and "Out" hoses (I guess) are connected at the bottom of the valve. Can anybody tell, which fittings I should use for the lines and what kind of threads I am going to find? There is a threaded nipple on the upper left hand side (thread on the outside) and at the bottom, roughly between in- and output. I would appreciate any advice and or pics of the installation. Thanks
Heinz, Germany
  • Posted 11 Mar 2021 01:43
  • By Heinz_S
  • joined 19 Jun'17 - 5 messages
  • NRW, Germany
Keep going
Heinz
You may have to purchase an auxiliary valve to the right side of the two spool valve that came with the truck.hope that helps
  • Posted 15 Mar 2021 01:06
  • By forkliftpete
  • joined 19 Nov'14 - 24 messages
Briefs United States
Toyota 02-8FD25
Terberg YT222
