Crown WP2300 Series Completely Inop
Hello friends. I currently have a Crown wp2300 forklift that will not charge and will not turn on. The cables are good and i can trace voltage all throughout the main power circuits from the battery itself to the 125 AMP fuse and even to the controller posts (controller is a new reman as well). when i plug it in to charge nothing happens and no LED's illuminate. i noticed i do have an hour meter display only. has anyone even had an issue with the onboard charging unit since its own wiring is tied into the system most importantly the key switch itself. i was wondering if the onboard charger can cause a complete inop of the unit?
  • Posted 18 Feb 2021 23:51
  • By JeffADHD
  • joined 18 Feb'21 - 4 messages
~*-Jeff-*~
Is the charger gold or black? Gold is old and black is where it's at. The gold charger will have a loud fan noise as the blacking e will not. When it's turned on. Those chargers will not turn on unless they see over 18 volts. You need to check your volts at the battery connector. Black on negative and red on positive. Checking DC voltage. Sorry I don't know how green you are or anyone is for that matter. If below 18 volts you need to truck the charger. You can do that by grabbing another truck (pallet jack, epj, wp). Take the battery connector from the good truck (battery side) and plug it into the bad truck (truck side). This will give the bdi a false service charge reading. Let it sit for a few minutes. Then disconnect and plug connectors back to normal positions. Use all safety equipment required for handling battery's. Then plug in charger and see if the fan turns on now. Or check your volts at the connectors again. See if it goes up from what ever it was at. You really need a dc amp reader to do this properly. Because sometimes the chargers will be putting out the volts but not the amps. If this didn't work. Get the trucks next to each other again and plug both battery packs into each other. While wearing safety gear. This will charge the other battery pack. The battery's will balance out. Let it sit for like 20 minutes. Then plug back to normal and try charging. If it's over 18 volts and still nothing you have a bad charger. There are more options as well. You just need to get creative. Let me know if that helps and if it doesn't I have more things for you to try. Good luck.
  • Posted 29 Oct 2024 12:57
  • By Ca4kLyft
  • joined 24 Oct'24 - 2 messages
Ca4kLyft
snowmaker@pacbell.net
David Coombs
***Update***
I managed to get my hands on an onboard charger from another unit and after swapping in the charger the unit now works. If the charging unit is inop or cooked the unit will do nothing MAYBE display hours if that. Thanks to those who offered advise ??
  • Posted 4 Mar 2021 22:24
  • By JeffADHD
~*-Jeff-*~
I appreciate this and will try it Monday thank you.
  • Posted 21 Feb 2021 13:55
  • By JeffADHD
~*-Jeff-*~
I am familiar with these trucks, but have not had any charger issues previously. All these newer machines disable the truck when the unit is charging. On other brands, you can connect the small wires together at the key switch so the machine will start up. If that works, then the charger is the reason it wont turn on.
  • Posted 21 Feb 2021 12:37
  • By PorkChop
  • joined 28 Dec'20 - 12 messages
Ah, I was thinking it was a much older machine. I'm not familiar with the setup you have. You might want to try searching for online manuals or contacting your local Crown dealer for a service manual.
  • Posted 20 Feb 2021 04:47
  • By lumberjack
  • joined 27 Jul'07 - 183 messages
  • Maryland, United States
My apologies for less than adequate info. The unit has a charger to the left side of the drive wheel with the hydraulic pump/motor to the right. the battery is new and sits in the middle of the Jack separate from the motors internal wiring and module. The main cables come in from the batter connector and run along the top to the module however the 10 amp fuse and the key switch is actually in line through the charger itself.
Newer versions of the charger look like this but this unit is a bit older and has the brass casing with no heat sinks
https://www.crown.com/content/dam/crown/images/products-page/forklifts-page/pallet-trucks/wp3000-onboard-charger.jpg
  • Posted 19 Feb 2021 17:02
  • Modified 19 Feb 2021 17:03 by poster
  • By JeffADHD
~*-Jeff-*~
I'm assuming this is a jack with the charger in the middle and two batteries on each side. Be sure that all four batteries have enough water to cover the cells before trying to charge. (if you're using flooded cell lead acid batteries)
The onboard charger is a completely separate unit from the pallet jack wiring. If your charger is bad, the batteries might be too low to run the jack. Measure the battery voltage at the connector both when trying to run and when trying to charge. It should charge at at least 25.5 volts. When trying to run it shouldn't drop below about 20 volts.
  • Posted 19 Feb 2021 12:56
  • By lumberjack
Maxlion FD30
Terberg YT222
REPOWERTEK Inc
