Service and OEM pass code
Hi all. I'm working on a aisle master 33NE. The wrench light is on and I need the service and or the OEM pass code so to access the display analyzer. Any help would be greatly appreciated.
  • Posted 22 Jan 2021 08:13
  • By Jesky71
  • joined 15 Feb'18 - 6 messages
i help everyone
Just in case anyone needs Aislemaster Technical support, for this or any other issues any where in the world, you can use this link.
Link is https://warranty.combilift.net/technical-support-form/
Combilift Technical Support is free to use
Thanks,
Richard
  • Posted 19 Nov 2021 03:20
  • By Richard_Irwin
  • joined 20 Feb'20 - 81 messages
  • Monaghan, Ireland
Hi , thanks for the information. When I get back to the customer I'll try it again. Thank you.
  • Posted 2 Feb 2021 08:10
  • By Jesky71
i help everyone
Hi,
Turn the keyswitch On.
Pull out the floor inspection plate and rotate to get access to the controllers plugs.
Connect your Curtis handheld or laptop with Curtis software to the Traction controllers plug.
Go to Parameters > Combi AM Master > Hourmeter Settings > Maintenance Settings.
Change the "Reset Maintenance" to On. (When you change this parameter, it will toggle to On momentarily then switch Off again).
Turn the keyswitch Off.
Disconnect the Curtis handheld or laptop.
Wait at least 5 seconds before keying back On.
If the service light turned Off then the procedure has been completed correctly.
Any issues please go to the web site (BLey has shared these already... Thank you Appreciated). Hope this helps.
  • Posted 22 Jan 2021 19:37
  • By Richard_Irwin
  • Monaghan, Ireland
Thank you for the reply. I do have the Curtis handset but there are no current codes. I deleted the history on both lift and travel motor controllers also. This unit has an onboard analyzer that requires a 4 digit pass code to access the " Engage" system.
  • Posted 22 Jan 2021 10:26
  • By Jesky71
i help everyone
I believe you will need a curtis controller handset or laptop cord and software with at least dealer access to reset or change the maintenance light/interval.
Or if you need any help from Combilift (AisleMaster) just go to thier web site either click the link to technical help (scroll to the bottom and select "Technical Support", or you can use the chat bot and it will point you in the correct direction.
  • Posted 22 Jan 2021 09:27
  • Modified 22 Jan 2021 09:33 by poster
  • By BLey
  • joined 31 Jul'20 - 59 messages
Terberg RT403
UN Forklift FGL35T
Sue Tomic Sue Tomic
