No hydraulic function while traveling.
I'm having a problem with this unit not having hydraulic function in the travel mode. If I let off the accelerator the function work fine. As soon as I touch the pedal they quit. There's no contacter pick up so the motor will not come on. I check the contacter for power it's getting a constant 36volts on the positive side and the negative is supplied bye the switches to the controller board. My negative drops out on the contacter. I can find anything wrong with the lift so I'm thinking it has to do with programming. Anyone have this problem before. Thanks.
  • Posted 6 Nov 2020 12:25
  • Modified 6 Nov 2020 12:26 by poster
  • By mark75
  • joined 20 Dec'12 - 4 messages
Red1875 @ icloud dot com. Send me an email.
  • Posted 13 Nov 2020 03:16
  • Modified 13 Nov 2020 13:45 by administrator
  • By ron_k
  • joined 2 Apr'15 - 128 messages
  • North Dakota, United States
4kliftman
I don't have the password for the unit. I just replaced the dash display board because the hour meter wasn't working. No the meter works but Still having the same problem that I started with. The unit has a new battery and has no shorts to case. Thank u.
  • Posted 13 Nov 2020 03:05
  • By mark75
Check settings for demo mode. Input password and change out of demo. Is hour meter reading? Possible dash circuit board or battery on board failed.
  • Posted 13 Nov 2020 00:17
  • By ron_k
4kliftman
Michel Denis Michel Denis
