Fuel not going past filter and solenoid
I have fuel going into the filter and not coming out of the solenoid. I have changed the whole filter and solenoid assy with no change. Need help asap.
  • Posted 16 Oct 2020 10:20
  • By curtis_b
  • joined 5 Jun'18 - 3 messages
That's what some people was saying
  • Posted 29 Dec 2020 06:42
  • By Andrew_Cuello
  • joined 18 Dec'20 - 5 messages
  • Hawaii, United States
AC
Glued??
  • Posted 29 Dec 2020 03:38
  • By Triggs
What needs to be glued in a regulator rebuild
  • Posted 29 Dec 2020 02:56
  • By Andrew_Cuello
AC
check to see if the injector is plugged with tar. I remove them and soak the tip in a cap of b12 or brake clean. You can also crank while doing this, if you dont see bubbles then its non operational
  • Posted 29 Dec 2020 02:21
  • By Triggs
I have fuel going to injector but not sure if the injector is firing. It has a hard time to start when it sits over night. Can spray Barkley into mixer starts up and runs fine. Anything you can help. Regular was just rebuilt but didn't touch the adjustment needle.
  • Posted 28 Dec 2020 06:33
  • By Andrew_Cuello
AC
So you don't have fuel getting to the regulator? Have you verified the main fuel solenoid is operational
  • Posted 24 Oct 2020 02:34
  • By Triggs
Sue Tomic Sue Tomic
Factory Cat MICROMAG20D
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Sue Tomic Sue Tomic
