Brakes
I have clark c500-50 circa 1983.
The bakes are useless a d clearly need some work. Could someone help me out with the process for servicing the brakes and handbrake please. I'll see if I want to give it a try.
  • Posted 6 May 2020 21:03
  • By JPS000
  • joined 6 May'20 - 2 messages
  • Suffolk, United Kingdom
you will find the brake drums inside the drive axle , studs on inside front behind mast, then others are behind tires 12 each side total , if memory serves me correct , it will pull out as assembly. then you can take off drums and wheel cylinders , change axle seals on carrier brg. supports before reassembly one side at a time, park brake should be drum on back of tranny good luck
  • Posted 8 May 2020 03:56
  • By stillworkin
  • joined 2 Nov'18 - 96 messages
Libiao Robotics
