52 Call Technician Support
Hello everyone
Model ERP25ALF2145
type D216A01529A
Year 2003
i have a problem with my forklift not driving (52 Call technician support)
  • Posted 22 Apr 2020 02:07
  • Modified 22 Apr 2020 02:09 by poster
  • By Tom_Wimber
  • joined 22 Apr'20 - 1 message
  • Macedonia, The Former Yugoslav Republic Of
if default passcode does not work to get dash access then it has been changed by dealer.
the only other way to gain access it by laptop program.
you will have to call dealer to access it and run diagnostic
  • Posted 6 Nov 2020 23:01
I Seyit from the turkey.
Available from ERP30ALF model of the above machine.
Both walking and hydraulics do not work on the machine.
There is no fault code on the screen.
Do you have a password other than......five five five for on-screen settings?
Where may this malfunction be caused?
  • Posted 6 Nov 2020 20:21
  • By Seyit_AKCAN
  • joined 20 Aug'20 - 5 messages
  • Turkey
SEYIT AKCAN
Code 52 Line Contactor driver shorted on start up. Check power cables going to motor, make sure all connections are tight and cable has not rubbed a hole against the frame. Verify all wires going to contactor are good. Verify all switches are working correctly, ie seat switch, park brake switch, throttle switch. Should all check good, suspect controller failed. Need to check with program before replacing or swap with sister truck.
  • Posted 24 Apr 2020 21:53
  • By Fishmech
  • Virginia, United States
