Intermittent crank
On this Nissan sometimes it will fire right up 60 times in a row and other times you hit the key and just get clicks through some testing I figured out the starter solenoid isn't always getting power all the relays are operational I can't find a break in any wires I have checked everything in the circuit it all works properly I have also cleaned the 2 grounds I have found one on the block and one on the frame please help thank you
  • Posted 1 Apr 2020 23:05
  • By Quinton_Baker
  • joined 1 Apr'20 - 8 messages
  • Wisconsin, United States
Qbaker
Thanks guys it turned out to be the relay block
  • Posted 10 Apr 2020 00:59
  • By Quinton_Baker
Qbaker
There is also a switch to prefend starting when in forward or backwards.
Mostly on top of the gearbox, if to much resistance the starter will not work.
  • Posted 2 Apr 2020 18:45
  • By John50
  • joined 7 Sep'19 - 153 messages
  • Netherlands
I have I think I have it narrowed down to the relay block with the starter relay in it I'll know when the part comes in thank you though I didn't know that one was there until this afternoon
  • Posted 2 Apr 2020 10:09
  • By Quinton_Baker
Qbaker
Have you checked the blue relay inside the front dash cover? I had the same problem and found the relay was going bad.
  • Posted 2 Apr 2020 10:07
  • By rc_w
  • joined 6 Apr'11 - 6 messages
Mitsubishi Logisnext FD25T5M
Maxlion R2D35
