coast
DISPLAY SAYS COAST ON AS SOON AS I LOWER HANDLE AND HANDLE IS HARD TO RAISE OR LOWER. FIRST HOW IS COAST ACTIVATED AND DO YOU HAVE TO TURN IT OFF. CAN I DISCONNECT IT
  • Posted 25 Jan 2020 08:43
  • By MRLIFTOFNY
  • joined 11 Sep'08 - 51 messages
EMAIL ; MRLIFTOFNY@AOL.COM
THIS HAS AN ELECTRICAL COAST BRAKE NOT MANUEL AS YOU DESCRIBE, ON THE DIGITAL READOUT IT SAYS COAST ON AS SOON AS I LOWER HANDLE. THIS IS A PE4500 WITH ACCESS 3.
  • Posted 30 Jan 2020 23:56
  • By MRLIFTOFNY
there is a flip switch at the bottom of the handle that allows it to go into coast mode. for manual moving.
but the handle being hard/tough to raise and lower might be due the spring in the bar.
if the switch for coast isnt on you might have a broken wire. either in the handle bar itself(there is a wire that runs through it so it one of the spring broke it may have damaged the wire)
also there is a switch underneath where the bottom of the handle is near the top of the motor. might have a broken wire there or a lose/bad connection.
hope this helps.
  • Posted 29 Jan 2020 15:08
  • By Mechanic_1217
  • joined 31 May'19 - 9 messages
Combilift Ltd
